3rd cylinder injector not working
1989RS
Today i have installed a TD05 and set of yellow injectors and a chipped ecu to run yellow injectors and a green afm in my BC5 legacy. Car was running fine before i put the ecu and injectors in. now it is bringing up fault code 14 15 16 17. It runs with a miss and if you remove the 3rd cylinder injector plug it does not change how it is running, but makes the car stall if you take any other injector plug off. what could be the cause of this. Thanks
got another injector off a mate with good seals put that in also took the spark plug out and made sure it was dry. the same problem occured. thinking it may be the ecu not working properly or something has fried inside it. any other ideas
Put multimeter over the injector plug - loom side and see if your getting a pulse - if not - check pulse at ecu plug
But remember un plugging the injector isn't proving the injector isn't firing - its proving that whole cylinder is mis firing - could be broken plug - earthing coil - dead coil - could be lots of things - even could mean the cylinder is dead on compression - worst case scenario really
Have u used a screw driver as a stethoscope to hear if the injector is pulsing ?
Got a multimeter that can pulse voltage and not just read values ? Put the probes in the loom plug and check if it's getting a signal - if not get a pin out so u know which wires are injector signal and check for pulses At the ecu end
