What would short fuse on amp???
bford
Had fuse(30)pop on amp and tried to replace and it pops straight away,tried turning amp settings etc on low head unit off.next I will try new earth wire somewhere else before higher fuse.just wondering is there anything else that could be the issue?
Fuse will pop even with all other wires out.if I add power or earth POP,mabe I should plug all in with power(battery) fuse out and see if that will work.wont solve the issue of why it popped the 1st place.tried searching net and only came back with add higher fuse.
could be internal short - burnt connection inside the amp - had this once and herd its common on powerplant amps
but check the wiring first also
DO NOT put a bigger fuse in - you will just cause whatever it is thats the problem to become worse and or melt wiring etc
Yeah was wiring issue at first they kept popping out(fixed by soldering wires).just a case of long weekend curse lol last one was speedo cable and now this,anyway I put it down to amp as everything else is fine.ill try see if I can take back to be fixed
Hooking up speakers backwards won't pop an amp. Hooking up power and ground backwards will usually instantly pop all the fuses on the end. If that parts fine, it's either a short in a transformer winding (pretty uncommon) or blown mosfet/s in the power supply section. And depending on the amp, often the power section only blows because there's a short circuit in the output section...
