Subaru EJ20TT, why pause ard 6PSI before boosting up to 15psi on primary??
Hi all,
This has been bugging me for a while.. when i press hard on the accelerator from vacuum, primary boost goes up to 6psi, pauses for ard half a second, then boosts up to 15psi no probs..
The thing is this doesn't happen as long as I keep boost above vacuum..
So:
Vacuuum -> Accelerate -> ~6Psi pause -> boost all the way upto 15
non-vacuum (~1~2psi) -> Accelerate -> no pause, boost all the way upto 15 straightaway
This is all below 4000rpm before secondary turbo
Cheers :D
suspect Factory boost control is trying to increase boost a little more slowly from vacuum, rathre than letting it jump straight up to 9and spiking over0 15psi
Jedi GTFO
Guest jedi warrior
 JoKer said:
Jedi GTFO
cry me a river joker...
to original poster.. try a zerosports controller.. will sort it :)
Isn't 15psi quite a bit high for primary? Mine was boosting 14psi on primary, and everyone said that was high...
Maybe post some more details on the car (yeah, engine, turbo's etc.), are you running anything like a boost controller?
 jedi warrior']
[quote name='JoKer said:
Jedi GTFO
Yeh I already have sequential controller installed :) hm.. in cold weather, goes upto 17
Ah.. so it is factory boost control for safety reasons... :(
