BG power light
for the last few days every time have started this tx s the power light has flashed 16 times yet it runs fine why?
unlike my 250t which also flashes between 8-16 times on startup will idle for 10 secs or 10 minutes, will drive for 100m or 100km without hesitating or stalling the under bonnet fuel filters have been swapped between cars and although the 250t s one was only partly full no thing has changed even removed the fuel pump and senders and squeaky clean apart from a bit of rubbish on the passenger side pickup.
Changed it from AWD to FWD. They have that in there for when you get a flat tyre and need to use a space saver bro. Obviously you never put a space saver on the front so you use that fuse and whack one on the back because if you have a wheel that is a different size or different size tyre on there it will blow. You aren't meant to just cruise around in FWD it is really bad for the car. Running gear will start breaking on you fairly soon if you don't go back to AWD
