Turbo Back Exhaust Tuning
Hi,
New to all this modifications etc! I have a 2001 Wrx Impreza, EJ20.
I want to install a "TURBO BACK EXHAUST".
1) Does it need to be tuned?
2) Can i tune myself if possible and is there CONS and PROS doing it myself?
3) What if i do not tune the car. What can happen?
Thanks
Ryan
If you've still got a factorycatted downpipe they are quite restrictive, if you get a is quality downpipe with no cat you'll find it frees things up abit and you may see an extra psi of boost.
Thats what I found on a v5 going from a factory catted downpipe to a 2.5 inch rage one.
Both setups had the same exhaust system which is a fujitsubo jasma spec exhaust.
 Subi-Driver said:
Hi,
Thanks
Ryan
is yours a sti on wrx?
to answer the questions:
1 - no not really need to retune as the ecu will compensate for the extra flow (see notes at end of post)
2 - yes u can.
pro - its not too expensive to do and u will have fun
con - u mess it up = not fun blowing ur engine and whole lot more expensive (not scaring u but thats happened to few ppl)
3 - nothing - the ecu will compensate for the new setup
notes:
i have done the exact same test on few v7
stock power = 170-175kw
modified with full turbo back and front mount (stock tune) = 180-185kw
retuned on mods = 205-210kw
the tuned setup acctually had less knock and was better at fuel economy as well
 pappu']
[quote name='Subi-Driver said:
Hi,
Thanks
Ryan
2 - yes u can.
notes:
Hey Pappu,
Thanks for the info much appreciated. I will get in touch again once i have bought the exhuast.
Do you work on weekends and how long does the tune take?
 Subi-Driver']
Hi,
Thanks
Ryan
2 - yes u can.
notes:
Hey Pappu,
WRX
