What can make a tapping sound from the flywheel area?
 cpt kernow said:
Been there, done all the combos i can think of. but in everycase the sound only appears when power is going through the back of the clutch/primary drive.
Coasting in neutral with no ignition=no noise.
Maybe I should cut an access hatch to have a look.........;)
Coating in neutral with ign off will have 1st and 2nd gear not rotataing
So i'd suggest you coast (bout 20km/h) again and select gears leaving foot on clutch and see what happens,
I'd be very supprised if 1st or 2nd aint the cause
  • Replies 76
 Treecrusher']
Cut? why not just remove the rubber boot where the clutch fork goes in as already suggested?
I've already said that I peered inside and saw loads of shiny new burs all over the teeth. Didn't do it from the clutch fork as it's under the IC but from underneath behind the steering rack.
Anyways....
Started getting into it today. Took off the IC, starter etc etc and when I went to remove the engine steady I noticed
So I'm guessing that the nut dropped off, hit the inboard CV and flicked into the flywheel by the big gap right infront of it.
What do you reckon? Bit of a co-incedence ay.
Oww, good spotting. Sounds possible. Does the bolt look as though it just lost it's nut recently? Nut stuck somewhere that hits with the clutch off but not with it on, hmm, back of the flywheel, clutch moves crank because of a bit of endfloat caused by all those full rev launches, nut doesn't touch. Time for a magnet. Hope that's it.
That's a worry then. Those bolts don't come loose by them selves. I'd say that box has been worked on by some bugger that didn't know what they were doing, like really seriously didn;t know how to tighten bolts even, You should be worried... very worried!
So I'm here to end all the suspense.....
And the Winner is.....?
It all went well removin my first subie-box except I didn't know the driveshafts were held in with pins. And I was trying to lever the buggers out the box. Other than that it's all good.
Loads of those teeth are cracking but the ones shown are the worst. None missing either. Looks like I caught it early. Got a recon'd on the way due to a good hook up I know.
But is it easy/cheapish to fix this so I can sell this one?
Thanks for all your help people! :)
 Ichi Ban said:
My money is on your gearbox (from your discription)
1st or 2nd gear with a tooth missing
Take it to a workshop to have checked (5min diagnosis )
Yay , my diagnostic skills work even over the WWW
Same but I don't do any launches etc so could've been like it for a while. Theres about 4-5 cracked teeth in different places around it so not sure if their related to the same incident. The last guy may have been clutch happy tho?
I've put my new box in but too scared to turn the key incase the noise is still there.
Well good news-it drives!!!
My box works nicely and no shudders or grinding so I'm pretty stoked that it was a forester box so I'm not running different finals to each end-Like if it was converted to an impreza before I got it.
The only hickups are the tin heatshields on the exhaust/turbo rattle heaps so need to tighten and the speedo sensor doesn't work so it's thrown a CEL. Well I hope it's that, gonna pull it up now to make sure.
If the CEL is on and there's no speed sensor it doesn't pull as smoothly, I guess it's because it's in safe mode?
correct
You have cable speedo drive (correct?) in which case you either haven't clipped the two halves properly together or have managed to pull it off the back of the cluster (dash display)
If electronic, just plug it in :)
 5UBZRO']
[quote name='sickmatesick said:
could be a noisy clutch throwout bearing?
That would have been my first diagnosis since it was mention that it does it with the clutch partially engaged...
Took me a while to figure out how that little bugger worked when reassembling tho.
To remove I had to pull the pin on the fork and to put back in I had to whip off the clutch and remove the inside bush. then hope it engages when the housing's back on.
 cpt kernow']
Yea they are a push type clutch, first application of the clutch will engage the release bearing into the fingers. when you say "inside bush", what exactly do u mean by that?
Nope they are a PULL type clutch and you have to engage the relaese bearing into the pressure plate manually
