Can some one..? HOW TO to remove Gear box (possibly put it back on)
Lots of people seem to know how to pull a box out and put one back in..
I cant see that its terribly hard, Is someone kind enough to create a how to possibly with pics on the process?
If some one gets real keen possbily the putting it back in (stop the flamage) although its just the reverse process there is a knack to getting the input shaft to line up correct?
Thanks to anyone that knows.. Im weighing up the need/want to inspect my box as it keeps spitting out 4th gear, and its getting worse. When hammered (on the track for eg) i can only get it in under double clutch..
(not looking for thoughts on why its doing it) - Im already resigned to the fact its going to need splitting open.
My personal method is to leave the pressure plate bolts loose - the simply wiggling the gearbox lines everything up nicely. Once its on and seated flush, you can tighten the pressure plate through the clutch fork hole.
Very simple and fast and requires no extra tools. You just need to have an extension bar of the right length.
The hardest part of the job is dealing with all that turbo crap that gets in the way....oh AND cleaning up the smell of gearbox oil if you spill any.
Sounds like a whole pile of extra work for no reason
An old input shaft lines everything up perfectly (so pressure plate get bolted and torqued up)
Then simply put the transmision into gear while you slide it in, so you can turn the output shaft to align the clutch / input spline together
  • 3 weeks later...
Ha ha
Seen a guy remove MT on his back, hand slipped and the box landed on his head !!
The drain bung got him right in the eye socket !! OUCH
His face swelled up something bad ,
This still makes me cringe
Correct. The clutch bit in the middle is pretty straight forward. If i get REALLY bored im going to be fitting a new pressure plate to mine in the next couple weeks and will do a write up.
Have you done yours Nick?
We did Pauls in half and hour once on jackstands. Removing it that is. Had been in and out a few times that week cos the Excedy clutch we replaced (the brand new one) was stuffed. All on our backs on the concrete floor.
