Wing mirrors
Everything that has been said is not entirely correct
if the car pre 2000 then it can have either a inside OR a Drivers side
Post 2000 it HAS to have both an Inside and a RHS one
That's probably not entirely correct either. I suspect that you'll get pinged because the mirrors were factory fitted as standard, regardless of how old your car is. The removal would probably be considered a "modification" and therefore subject to a certification process. And it's pretty obvious they've been removed so you couldn't argue otherwise.
LVVTA Threshold makes no mention of it.
