Someone to rotate comp housing wellington
petrolheadjman
So I just got a td05 courtesy of rex-leggy but I need to rotate the comp housing 180 deg to fit in with my piping setup.
this is easy on a vf23 like I had because of the clips on the back but the td05 has bolts instead and only 2 of them.
So I was wondering if anyone knew of a place I could go to get this sorted during the week? Will need an alloy welder
 kamineko said:
i\'ve got a td05 in bits at the moment. seems like you can just sort the location pin on the housing, and make a crescent shaped bracket for the wastegate? you can offset the thickness of the bracket with the adjustment on the arm
Hadn\'t thought of that. Will have a looksy
I have just heard of people welding nuts in place so I thought that was the best option
drill new holes through the actuator bracket where ever they line up with bolt holes in the comp housing .
use the left over tab things around the rest of it
thats what i did on loganrasti \'s car ;D
edit . that was a vf23 . looking at pic it wont work on a TDopuu
Wont work as above chap. Its not a vf. Its not flipping it thats the problem its wtf do I mount the actuator too. Similar to evo td05 you cant flip with internal it mounts on the front of the comp housing.
