Think i blew my 6 speed
Minaj
Well driving on highway changed from 3rd to 4th with force my gear leaver was all slopy had no gears at all it\'s stuck in 4th gear tryed pressing clutch in and changing gears but nothing seems to b there wont get out of 4th gear. So what too doo now? take gearbox off? Note: 4th gear syncro was fucked anyways
You havent "blown" the gearbox - you have broken the selector arm which pulls/pushes the shaft into gears. Its a stupidly small part which usually gives way due to rough/forceful shifting (mainly caused by f**ked synchros) and leaves you stuck in 4th gear. I recently broke the same thing... this is what it looks like:
Easy enough to fix - just have to take the rear housing of the gearbox off and its right there (gearbox out job though). The ball that breaks off just usually drops to the bottom of the casing and doesnt interfere with anything so need to worry about that. But if your synchros are stuffed, then you\'d be advised to get that sorted as well to lessen the chance of it happening again.
As a note, the above part is $197 + GST from Subaru, but there are none available in the country at the moment - ex-japan, 1.5 weeks wait if you order.
yep seen that one! or the selector with the solid little rectangle tab that pulls them out of gear.
 boon']
[quote name='Minaj said:
Sweeet, will take off gearbox in weekend probally will give it to a gearbox rebuilder might want some longer ratios while im at it
260kph not enough?
from what i understand he wants to finish 1/4 mile in 4th gear
 SP00N']
260kph not enough?
Go to 5sp lol. But really, people in US pull 10s with 6sp boxes.
Is he ever going to finish the quarter in decent time in 4th with a longer ratio in a 6sp tho? Thought it would hit limiter in 4th way quicker than 400m but idk no real world experience all theory lol.
Nothings bullet proof imo.
Yeah, but theres variations.
From memory the earlier ones (and I stand to be corrected) are a little harder to find second hand parts for due to the smaller amount made. The later version 8 and onwards are the more sought after ones.
