Even though they have grey top injectors are they 440cc???
380s will be good for around 180kw at the wheels after that 440cc yellow tops from V3/4 STI and you'll crack 200kw@wheels.
Then you'll have to go aftermarket and require a Tunable ECU.
thought so, just that Im selling some on trade me and one guy seems to think theyr 440.....almost pissed me off abit there because I was thinking I bought me v3 yellows for nothing!
If you test the grey injectors at 100% duty cycle they actually flow about 440cc. The yellows flow about 520cc.
But injectors are rated at 80% duty cycle which is when they flow 380cc and 440cc respectively. If you read up the american sites they call the grey tops 440's and the yellows 550's.
well i suppose you cant go wrong with the yellows then...thanks for the more info koom now I know why one of the bro's keep telling me the grey tops are 440's haha I think I owe him an apology and a box!
The Grey's are still rated as 380's though.
I flow tested some 740cc injectors and they flowed about 830cc's at 100%. I think the standard for them is to rate them on what they flow at 80% as they're not supposed to be run at 100%.
The results I got were using a factory pressure reg which ran at 43 psi (~2.97 Bar).
If the Japanese test at lower pressures its probably due to them following a different standard for their procedures than what the yanks do.
