Fluid levels BH tail lights...
Bugle
So leaky tail lights are a BH \'thing\'?
A friend has one and asked the question, didn\'t think much of it until I was behind one last night with water sloshing around in both tail light assemblies (lights seemed to be going fine though)
So how does it get in and how does one fix it?
On mine, theres a small drain slot in the middle of the garnish where water thats run off the rear screen would normally go behind the light and pop out somewhere above the number plate. On mine, the water pools at that slot and leaks into the light.
I fixed mine by removing the whole thing and running a bead of sealant all along the top edge with extra focus in the centre.
Pretty sure georges one leaked too and we fixed it the same way....oh and mike youngs one.
Do a quick search, however the basic process
remove the garnish
drain water
clean properly, then clean the balck trim strip and the garnish and the body with nailpolish remover
use windscreen sealant and run a bead of this along both ends of the black trim strip
put it back together
it will not leak again if done right
