sti v7 - pod fiter / external wastegate and engine lights one
victorjf
so... my friend just got a sti v7 with pod filter apex external wastegate and 3 exhaust from turbo, but now his car got check engine light on ( orange one ). He bought this car about 1 week ago..... also turbo kicks only with 3.5 thousands revs ( not sure if it is normal on v7 due my cg8 kicks b4 3thousands revs ) and when the check engine light comes on, the idle stays between 900 to 1400 revs ( going down and up ). i said to him to take his car to the garage and see whats wrong but seems that air flow meter gone...... we did reset the ecu but after 5, 10 minutes the engine light come on and no idle again.... has anyone been through this issue before ?
we did it... and when we turn engine bk on the check engine light is not on anymore, and then we go for a drive and after first boost engine light comes on and no idle.... im pretty sure is afm too... we checked pod filter and sensor, is all good, hes going to buy the crc maf cleaner this week...hope helps
Im happy to be told wrong but isn\'t the "maf cleaner" just normal electrical contact cleaner anyway?
The car might behave better like timmah said, with the afm unplugged altogether until it can be sorted? Has worked for me - drives terribly with busted afm but unplugging it means no more bad signals
Where in the country are you? There\'s probably someone local who might be able to test their afm and make sure it actually is the problem
Until you find out and fix the problem I\'d strongly advise just driving it gently & keeping it off boost, the check engine light means it will be in limp mode which is exactly that - it\'s meant for you to baby the car home to get fixed
Just to clarify, I wasn\'t intending to imply to run the car with the AFM unplugged altogether, was just to simply see how it operate. It was how I identified a dud AFM I had.
What part of country are u in?
Gt it scanned
Do a runnin log as that will show exactly what is issue
Sometimes a scan is not the right answer especially if it\'s things like leaks
Have had a similar issue in a car I diagnosed and code was p0171 which sometimes looks like ATM but was in fact a leak
