starter motor failure modes?
kamineko
\'96 BG5 200thou kms
so it seemed that my battery was flat - starter motor turned barely enough to start the car, then not enough, then less, then not at all. now just one click with the key turned
car will roll-start, but i cannot jump start with another running car - either parallel to my battery or replacing it.
just the same one click sound - maybe this is the starter engagement onto the flywheel, barely, then no drive from the starter motor?
can i assume the starter motor has failed? bushes gone?
cheers
Quick way to test starter solenoid is to use a screwdriver and short across it (make sure car is in neutral!) from batt terminal on solenoid to starter terminal altho its pretty hard to get to in the subie....plenty of sparks and stater will come to life if brushes are ok. If brushes kaput, nothing will happen :) - check grounding wires for shits-n-giggles
B4_685 via Tapatalk HD
 kamineko said:
yeah i meant to type brushes, not bushes. my bad
just didn\'t want to pull off the TT intercooler in the rain to find the starter was OK
will swap it out tomorrow
cheers :)
I haven\'t been brave enough to remove said top mount intercooler lol
Yeah good work, but if they get too worn it wil blow holes in the armature = $$
funny to see it has a planetary gear starter too I made my previous assumptions based on it being a reduction drive starter
 Roo said:
Needs new brushes mate
and welcome to the world of TT\'s everything is different
nope Impreza starter not fit ONLY another tt starter : as you found, gotta clear second (primary) turbo
sounds like a plan. my cars are always being pulled apart, and I do naff-all kilometres. next time its in bits I\'ll refresh it. then again, it\'ll probably be getting a single conversion and I can use my impreza starter instead :P
