'01 B4 RSK Rev.C random pulling to the right
Dairusire
Hi guys, so heres a bit a of a weird one, I recentl (last night) put on some v7 STI wheels 225x45x17 with some re-01r tires onto my car.
Now after this the car is giving me grief with a completely random pull to the right. It\'s also not consistant, like when a wheel is out of alignment. It\'s more like being buffeted by some SERIOUSLY strong wind. Sometimes it pulls, and then it will drive perfectly straight. Sometimes it will pull under braking and sometimes it doesn\'t.
It also only pulls to the right. All the wheels are tight, balanced etc. I\'m at a bit of a loss on this one.
EDIT: just so you know it doesn\'t pull for long, about half a second to a second. It\'s also like the steering wheel is turning itself.
I had this behaviour on my V7 when I went to RE070\'s. It was because the sidewalls are so rigid that the car will have a tendency to track little things in the road, often surprisingly strongly. Felt exactly like you describe.
I think it sounds like bump steer, where bumps in the road have an effect of steering. Putting the new wheels and tires on changes the steering axis inclination angles and the scrub radius this in combination with the stiff sideways of the tyre (like boon describes) probably makes the problem more noticeable.
Check all steering components for free play and try lowering your tyre pressures slightly. Also try getting your wheel alignment adjusted to compensate for the larger wheels it should help out a little.
thats not bump steer . bump steer is to do with changed relationship between suspension arms and the steering arms when you lower a car lots
this is called tram lining . the car follows any lines , trenches , contours in the road .
it could be that the car has very little castor and someone has given it a specific wheel alignment to make it not fall off the left side of the road . now that you have way stiffer tires it is too much
