Legacy GT BP - Traction control
allycat
Cool thanks Guys, mine does not have any button so assuming there us no TC or brake intervention. The reason I ask as I went into a round about abit too fast on a wet day and I felt the car trying to break when I was full on the gas coming out ??? so figured out the problem, don\'t drive fast around round about\'s ;)
 subirex said:
all bp legacy has traction control system equipped, some premium specs come with VDC which can be turned on and off using switch. my 2003 bp5 gt has traction control in it. more info from here
http://www.planetsubaru.com/subaru-vehicle-dynamics-control-vdc.htm
and, allycat, you do have traction control in your car
Wrong, not all bp legacy have traction control. I have had 2 and both have not had traction control. I can quite happily spin around in grass/mud/slippery road no problem with no intervention of the car
My 07 BL definitely doesn\'t have traction control. VDC is a collection of different technologies, and BL/BP have many of them as standard, but not traction control. If you have traction control, you can manually disable it temporarily with a VDC Off button (far right button of the three under your electric rear view mirror adjustment knob), but the rest of the VDC systems remain on permanently.
Thanks AJ , is there a simple on off switch somewhere?
That planetsubaru link refers to USDM models not the JDM models you guys get. I\'m pretty sure VDC was only on auto models for BL/BP A-C. Can\'t remember if manuals got it for D-F. BP5F (08/09) has it but no button to disable it whereas my old BPE Outback had a button on the panel between the steering wheel and the stereo.
