Hey there, thanks in advance for any information you may have in regards to putting a v1 sti ecu into a v2 wrx?
what I have researched on the net is that the engines were mechanically the same between the v1 wrx and v1 sti and that its the ecu that was the only difference in performance is this true?
I also read that the v1 wrx was open deck and the v1 sti was closed deck and the cams were slightly different (what does this mean as I am not very knowlegable with cars) and that the internals were not forged until v2 sti\'s.
all in all though my main question is... is it safe to put this v1 STi ecu in my v2 wrx or will I melt something or will something go bang? because I figure that going from 10.5psi to 14psi is quite a jump.
I realize these cars are getting old now and people are talking on subjects of later models but I do appreciate any help you guys can give.
 DacerX said:
shouldnt really be a big issue
+1
WRX Version 1/2 specs:
http://www.subaru-impreza.org/forum/technical-general/49956-jdm-classic-impreza-specs.html
STI Version 1/2 specs:
http://www.subaru-impreza.org/forum/technical-general/75415-jdm-classic-sti-specs.html
Looks like they both have 8.5:1CR and a 7000rpm limit, so should be a perfect swap. Just double check that they both use the same injectors? (Version 3 STI, CR changes to 8.0:1 and red line lifts to 7900rpm).
Also if the WRX and the STI use the same boost solenoid and turbo. They could have a different sized restrictor pill in the waste gate line, for the altered boost levels. So you might need the different pill to go with the ECU? You will soon know if you still only get 10.5 psi.
 Rosssub']
+1
I don\'t think that information is correct as all version 2 sti I\'ve seen have had the 7900 limit and 380cc grey injectors.
Just put it in; Run 98 octane and keep an eye on boost levels, it may overboost, possibly in the higher gears.
If so, you can remedy this.
Been done before, time and time again. This is where you look at an in tank pump upgrade and split fuel rail.
Yeah i agree, my brother has done this mod and if you keep good fuel and plugs in it it will go well. Might jsut have to watch the boost and turn it down a little if you get det. Also a version 1 sti may not be much more aggressive than your current ecu if you have a sedan, a version 2 sti ecu may be a better option?
thanks for all your replies, mine is a wagon wrx so its running a td04 but I will be replacing with a td05 at the same time as the ecu swap.
I was advised to run a new fuel pump as well but wasn\'t told about split fuel rails.
