Car Crimes
Joker
Stock BH sub is 8ohm. Also requires the correct mounting in the body to transmit the sound properly. 2 of them in 6x9 enclosures with seperate tweeters could work tho.
 ReubenH said:
Yeah, i was told of the 8ohm problem this weekend, and my BG is most likely 4ohm. Sill, there is probably an aftermarket option that will fit in the pointless right hand boot pocket thing...
Thats why you get 2 of them :D
Bass output from them is pretty limited anyways so its a waste of time if you ask me. In the McIntosh equipped cars, the front and rear components do most of the hard work
 wrx_lou']
[quote name='JoKer said:
many subs require only about 1 cubic foot of "enclosure" to operate at optimum levels {RTFM}
excessive space only makes they work worser
most are usualy about 30-35lt for a 12 inch in a sealed box. needs to be larger if its ported. The larger you make it the lower the tone but you can go overboard.
thats rite the box does have a ported 12 on top of the box
I saw the worst goddamn thing ever yesterday. Was what appeared to be an r33 skyline, about 2cm off the ground, no bonnet, the turbo was ABOVE where the bonnet would have been with an airfilter strapped on to it, and then the exhaust / wastegate exhaust running out a J-pipe...straight up...above the engine...2 metres off the ground.
and the peice de resistance was the damned exhaust thing had a hinged cap on top...like some smokestacks have...so everytime he blipped the throttle it went CLANG.
WHAT THE HELL. I was praying for a cop to drive by, but no. I took a camera phone pic, pretty bad quality but I'll chuck it up if it's possible to see anything in it.
 leggyfreak said:
exaclty i saw an other one today but didn't have my camera on me it was a 1989 toyota carona or 19 inch chromes
didn't you know man thats like GANGSTA as these days hahaha FAIL
