Take a look here, the gist of it is the same, but obviously you can skip allot buy just buying the complete engine. it's been done a couple of times, no one seems to have/want to share the ECU pinouts though which will detail any minor differences between the looms (such as the ignition wiring). I think cause those who have done it have gone with aftermarket ECU's. It would be great if someone could tell us properly what needs to be done for the BE/BH's
Also, later model BE/BH's got different ECU's. I don't know which is which, and which works with the STi's.
does the gearbox need to be changed if I am to put an sti engine in? clutch? flywheel?
Would there be much difficulty in putting a v7 sti engine in?
 sylus']
does the gearbox need to be changed if I am to put an sti engine in?clutch? flywheel?
No, no and no.
Same clutch and flywheel and the gearbox's are physically the same.
Yes!
V7 has AVCS and if your car dosen't that means a whole lot of work and you'll need to fit an aftermarket ECU that can run AVCS.
In your original question are you asking about just replacing your long motor with one from a V5/6 sti or are you asking about a full TT>T swap?
Because if it's just the long motor your wanting to put in then there is no need for any wiring/ECU mods at all.
You just bolt all the bits off your motor onto the V5 motor - only tricky part is modifying the LH head to accept oil and coolant feed/return lines for the turbo...
For single turbo or parallel twin turbo...
The ecu wiring requires a few wires to be swapped around and the variable fuel pump control needs to be rewired.
This will allow a v5 / v6 sti ecu to be plugged straight in.
How about with engine mounts? Would I be able to just drop in a V5-6 without having to change mounts, etc etc? I'd just need V5-6 loom, ecu and engine right?
ver 5/6 engine swap would be the easiest as it runs same loom. v3/4 will require you to wire in completley different ecu
Yeah but longblock wise, the GTB's manifolds, and sensors etc would bolt on right? Or are the incompatible?
Even if they worked though... the GTB's ECU's tune would not match up with the V3 block. May be a couple of HP wasted there?
thats why v5 conversion would be easiest as manifold, heads etc all match up as well with ecu being very similar pinouts. even if you only used shortblock and used gtb heads, intake manifold etc etc
  • 2 months later...
hey would the cheapest option for this be buy an old rs engine (single turbo) and use the bits off it? but use an upgraded turbo vf22? ive been offered a complete engine 300 bucks with a slight knock
slight knock probably means its roo ted
99 b4 has been done with v7 sti engine - needed pretty much loom swap to run the 7 ecu
if u got the engine and loom then yes its not too bad to do
    574.7k
