Testing EGBP
Andy_Mac
After a relatively cheap solution for testing EGBP. Anyone else hacked up a DIY solution before.
I'm intrigued to see what kind of backpressure the stock post turbo exhaust is actually generating rather than just taking the standard advice that it needs to be swapped out.
Could probably do something povo with a peak holding pressure gauge and some copper tubing for spacing to reduce the temp before getting to the sensor, but actually being able to log the difference across the rev range would be a nice bonus.
  • Replies 53
Thought about just getting a long vac hose an feeding it into the cabin somewhere for a mechanical boost gauge then just recording the what pressure it gets at certain rev ranges and chucking it into an excell graph along with the standard logged figures aswell.
 lachlan said:
the budgo way to datalog is put the boost gauges near each other and record a video with your phone haha
Yea thats an option but its easy to just watch boost guage. Sure it might not read high enough but when egbp hits a wall its blatantly obvious when it skyrockets and you know you have an issue.
Alright so talked to a exhaust crowd who can supply and install o2 bungs for next to nothing so figured i might as well just get a 2nd one welded on. Would it be best to have it right at the top of the downpipe nearish the existing o2 sensor or further down near the other end of the downpipe? Don't suppose it'll make much difference other than having less perceived back pressure the further away it is due to the gas cooling?
Edited by Andy_Mac
 evowrx said:
Goes in up pipe.
Was planning on starting with the downpipe to see what kind of pressure the post turbo part of the exhaust is generating. Trying to find tangible data to backup whether a full exhaust is needed or not.
Also for a twinscroll won't you need to get bungs installed on both paths of the uppipe, these ones don't have cats in the uppipes either so thats alot of the usual restriction gone
Pre is the big one. I didnt bother testing post as it was so low last time. Na one scroll would be fine. The big restriction is the turbine/housing not the 2.5" tb exhaust. At 227wkw vf22@20psi there was a marked difference between 2.5 and 3.
Aren't you still wanting to maintain a certain amount of pre turbo backpressure to help spool?
Is that no noticeable difference with stock or a big custom one? I'm kinda more interested in what keeping the stock turbo back exhaust is doing to the performance potential of it. And then the difference between the two when i eventually swap it out.
Or is the difference going to be low enough that i'm just wasting my time?
For the uppipe is it all that important having it right near the turbo or is at the bottom good enough? Potentially saves needing to completely remove the uppipe if it can be done at the bottom
Closer to 1:1 the worse the spool but doubt you will be under 2:1 at 18psi on stock snorter. Anything post just compounds the issue but worth doin. I didnt bother as with 1.26:1 20psi/6k and 20psi by 4k on 2l it didnt warrant checking.
With the vf22 it was worth swapping out to the 3in. Thats at a guess moving 38lb/m.
Im taking mine from collector just before up pipe cant see it changing much.
