PLAYDAY 9th and 10th NOV 09 HAMPTON DOWNS
Hi people November the 9th is fully booked, yeah after only 6 days we are booked out, we are trying to get another day and will keep you posted. We have people entering the 30th fast as well.
  • Replies 54
Guest STiEVO
 nt_a_foz said:
Might put my name down for jan then..
Do we just pay now ...??
i would seeing as it took 6 days to fill the nov one.
Guest STiEVO
i moved mine to the 10th haha :P and daniel and ainsley are also coming . dan may be bringing a r32 gtr if all goes well. will see i guess
I walked the track on Sunday and you really can’t compare it with anywhere in this country, it has hills and they are a lot steeper than they look (mind you I am not the fittest). Also that hairpin closest to the apartments on the infield, there is a short straight (maybe 160Ks) up hill and over a blind crest with about 50 meters till you are right in the middle of the hairpin, very hard to get your braking point sorted on that one. That should be the best viewing point for the spectators.
The whole track is brilliant, very fast, very tight, lots of hills and dips also good camber on the corners. Bad points run off area’s maybe a bit small but hard to tell as construction still in progress, the Armco is track side in places.
The first day there will only be the start of a very long process of learning a new bit of concrete to go for a skid on
  • 2 months later...
well.. my beginners mistake was to be aggressive. my new r888's got too hot. set yourself up for the corner and load them up. just turning in will net an overheated tyre and less grip ~in my experience..
wish i could be up there as well.. hope you all have fun!
Thats good advice. The grip is different to running on road tyres and should follow the mantra of "slow is smooth and smooth is fast......."
i.e. no sudden movements.
+1 as above, I destroyed my lip at my last trackday and almost rolled from not following the smoothe is fast philosophy with my also new set of R888's. Caused my rear end to step out and I was a passenger the rest of the way.
