What I think is my handbrake lite on the dash is staying on, it originally was an intermittant problem but now it wont turn off, I have also checked fluid in the resiviour(sp) any other things to check?
take the bulb out 8)
or you could check the switch by the handbrake. might not be getting pushed properly or shorting out or something.
The rubber boot inside the brake fluid cap isn't holding the sensor down is it??
sometimes the sensor (float switch) is bung, happened in our old 94 legacy. try unplugging the connector from the brake fluid reservoir and see if your ! changes
It must have been the rubber boot as i took the cap off and had a look, all seemed to be in order, but it back on and the light is gone,
Cheers guys
