I am trying to wire up the speed sensor and ground the ECU pin on my 2000 GG9 Impreza (EJ204). I can't find a wiring diagram that tells me which pin I need to ground to get the ECU into manual mode. I also need to wire up the speed sensor from the new trans which is a 2001 WRX box with the 3 pin connector. Can anyone provide the info I need? Cheers
There is a link in this thread to one for a v7 sti, it may be similar but there is likely a lot of differences so take it with a grain of salt.
Edit: I had a look through it, it appears there is a wiring diagram for the inhibitor switch operation in there so it should be able to help you solve your problem. As always try to verify that this information is identical with what is on your car before you start grounding random wires.
Edited by IZichard
Hey mate, look at page WI-68 (wrx) or WI-79(n/a) of the service manual I PM'd you the other day. that gives you the pinout of the speed sensor and how to connect it to the cluster. WI-69 shows the pinout and connections of the inhibitor switch and starter interlock.
I've historically left the auto ecu in and just jumped the TCU to park at the trans end of the connectors, not sure how well it works in the newer cars.
Forgot to update but I got the speed sensor done. Still gotta do the ecu but I haven’t got around to it yet :)
  • 2 years later...
Hey there I've just done a manual conversion on a gg9 èj204. I need to wire up the speedo any pinouts available for the ecu i can do this. Please. Any help would be appreciated.
  • 7 months later...
Hey dude heres the TCU plug you need to tap into for the speed signal. If it's a 3 wire speed sensor one wire is power, one is negative and one is signal.
Never saw your comment as I haven't used this site in a while. Just bought my Impreza back which I had manual converted after selling it in 2019. Still never found which wire one the ECU was the manual ID nor have I found a reliable pinout. Could probably get it retuned by a tuner so it just runs a manual map instead and it'll be sweet. Highly recommend Custom Culture and Tuning who did the same to my Legacy Spec.B when I converted that to 6 speed manual in July. Cheers!
Edited by SuperS0nic
1 minute ago, ej20sti said:
All good dude.. I just wired it straight to the ecu in the end.. all working well.
Good stuff, did you end up finding out which pin was the manual ID pin?
Yellow and green is vss one is power 12v switchable and other is earth.
Nah I mean which ECU pin you have to ground for manual mode
