So looking at buying another BH5 Legacy cos i miss my old one haha only thing is it needs a cambelt it was last done at 93,000kms and has now just done 212,000kms would it still be okay to drive it home to Nelson from Queenstown? obviously will get it done once I get it home
Listen for any nasty rattles or noise coming from cam covers and remove passenger side cover and check cam belt for wear and cracks.Purchased my bl in Nelson and drove back to Auckland with barely legal S*** tyres.Wellington to Auckland was in pouring rain and darkness.Bent a rim driving through Hamilton.
Edited by Dre
Nice - which passenger side cover are you talking about? I wont have tools with me in queenstown to check first
Front side cam cover below oil dip stick.4 x 10mm bolts.I have a mini Teng tools socket set 5.5 to 13mm sockets,various screw heads,extension and ratchet.All packaged in the size of a cigarette pack.Cost around $65.
TengTools BBX20
Edited by Dre
36 minutes ago, TNHSTI said:
Thanks for that -also anyone know where I can get all the part numbers for all parts needed in a cam belt kit?
Where are you planning on buying a kit from?
Partsouq but not sure of all the parts needed and part numbers and the dealers won't give me the part numbers
Put the chassis into partsouq and it'll bring up the parts specific for the car
Yeah can do that but not sure exactly what I need...
Cambelt, tensioner, idlers and waterpump. Up to you if you do the cam and crank seals, rule of thumb is if they aren't leaking leave them.
Tbh you might find winger has sharper pricing then partsouq (take freight into account with your pricing)
