Fronts bolt on rears do not work. Your best bet to 5x114.3 convert the rear would be either custom subframe from say nissan or re drill the hub flanges.
The bearings are a different size for a start, however the bolt in bearing carrier for the rear has a different (smaller on the 5x100 hub) bolt spacing. To swap to the larger bearing unit there's specialist marching required to the rear arms and an adapter plate fabricated.
Have a look at the 3rd from bottom post here
https://legacygt.com/forums/showthread.php/conversion-5x100-5x114-3-05-lgt-129874p12.html?highlight=hub+swap
Edited by Nachoooo
