Morning,
Just wondering what's available in the way of speaker replacement for 04 Legacy with McIntosh upgrade? Been around a few shops with no help and can't find much online.
6.5 inch sub, 3 inch speaker and 2 tweeters per door, seems to be pretty difficult to even find a set that fits in. Looking for something a half decent set that will run off the factory amp.
Have found online video of how to do everything but only found 2 sets in these sizes of brands I've never heard of. Figured someone here may have some recommendations.
Cher
Should be able to find some ok condition ones from a wreck if wanting to get things working on the cheap but they all fail at some point.
Main problem is they have an 8ohm impedance which is rather rare. Two bridged together gives 4ohms which others have done in the past but will somewhat take away from the full sound of the McIntosh and may sound crap as you won't have much adjustability to tweak the new speakers to the rest of the system.
Replacing the amp with a high level input one is the next best plan as it then lets you replace all the speakers with standard component/coaxial’s and gives you the ability to tune for the balance you desire.
