Anyone got feedback for these plugs?
I replaced the plugs yesterday with ILFR6B, which the NGK website and book said to use for the EJ20Y.
Running now, get a nasty hesitation above 3,000rpm all through the power range on boost.
I reverted back to stock tune, used my original coils etc and still does it, only thing that has changed is new plugs.
Now I check the FSM and they say to use SILFR6A for the turbo model? Would this cause the nasty hesitation when on the boost?
Originally the car was running LFR6AIX-P.
Thoughts?
Edited by logan25
4 minutes ago, Andy_Mac said:
Did you check the gaps we're correct before installing?
Might have to pull them and check. First time I have done plugs so will learn for next time.
Romraider reports no misfire, but it feels like it.
I've just dug out some old pics and I put the ILFR6B’s in my Legacy but from memory think the gap from new was like 1.1mm and it needed 0.6-7mm or something like that.
So pulled the plugs and found the culprit.
All the gaps were perfect, around 0.7mm ish.
One plug had in fact a small hairline crack in it, which I can only assume happened during install, even though was very careful. Regardless I chucked an old plug in to test, and pulls like it used too.
Ordered another and back on with the tune tomorrow once it arrives.
