I have a 2003(2002 model) Legacy BH5 auto GTB E-tune TT... and I'm having a hard time with what the "correct" radiator should be in the car. Some say the rad doesn't have a cap, but mine does. And, if I get one without a cap, does it matter? I can top up the fluid from the side reservoir.
Thanks!
have you got a Header tank too? Sounds like someone has put the wrong Radiator in it at some time
Auto or Manual?
Overflow isnt the Header tank I'm talking about
No header Tank then yes you'll need Radiator cap style rad (pictures might help of your engine bay)
but yes Auto is important part of the thing as there's a trans cooling loop built into the Radiator
Usually Turbo cars have a header tank, no turbos dont?
36463d1110782927-b4-engine-bay-layout-b4
the Header Tank it bottom Centre in that image above (I found in the internet) this setup will have no Radiator cap, the overlflow bottle wis just out of this shot to the right by the Battery location
36577d1111006375-b4-engine-bay-layout-b4
with the little blue hose going to it ^^ Lower middle of this image
Next is a WRX but still similar setup (another random Image from the internet)
No Rad cap, Header tank on the Driver side and over flow is not quite visible
chur yeah I was going to suggest an image of the car's ID Tag next so we can "see" what car he has
or image of your engine bay (you can upload low res images direct to the forums these days)
Thanks all for the details! It's a 2003 BH5 EJ206.
I did get the cap-less tank... works perfectly.
Car still performs like a slug... but that's another problem.
