what about the replacement turbo, what condition was that in?
just subscribing to this thread
  • Replies 56
When you complain about lag you *really* need to tell us what is happening with the boost. For example my VF10 equipped GT could be making 10psi at 2500rpm in 3rd. When I had a leaking pre-turbo exhaust it wouldn't get to 10psi until 3000rpm.
If you don't have a boost guage it is going to be hard to diagnose your problem.
Unless you mean it's missfiring? That's a different issue again, and is related to the coils rather than the turbocharger (assuming those were the only two changes).
i do have a boost gauge but it is only going up to 7psi and what i mean by lag is its not boosting propley im new to a turbo car as this is my first one so im not sure how to explain it.
thanks brad
lag is before the turbo kicks in, if its not boosting enough thats a different story, sounds like its running wastegate pressure
the air intake is stock stanard so how can i check that
its got to do with the vac/boost line plumbing,
ive got no idea how your car should be setup, mite be best to copy/check againist someone elses car or get a bleed tap and up the boost to see if it makes a differance.
thanks brad
i know you are new to turbo cars but can you explain what you see and feel, try to describe as best as possible? maybe it might gives us a better indication
7PSI is waste gate pressure so when you installed the turbo, did you put a vac (pipe) from the turbo outlet [the thing that goes to the intercooler] to the waste gate [thing that is bolted onto the turbo {possible gold or black in colour}] ???
seems to be working ok now but it not picking up till like 4000rpm
i just went and had a check and it looks fine to me
I'd say you have a vac / exhaust (possible both) leak somewhere then
Check the pipes for splits etc, try the exhaust gaskets bolts, see if they are tight
Has anybody asked the condition of the VF8?
Has it been rebuilt or has it been kicking around absorbing carbon since the beginning of the 90's?
it looks fine on the side i checked it over before i put it in
looked as a newbe would on anycar as its not the turbo as it is spoilling up
got camera but not the cable so will get a pic up tomorrow and that seems all fine but all the help will be good
 G-unit said:
postv a pic of how u have ya boost controller hooker up, the stock unit. bazza could u also please
no point for me, I'm running a pipe from turbo outlet to GFB boost controller to the turbo wastegate, easy simple and effective i found
but if you have the stock one setup it should do something like this
TOP - Should go to the turbo outlet
BOTTOM SIDE - Turbo Wastegate
BOTTOM - Back into the intake (that box if you still have it)
NOTE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
that bottom pipe should have a restrictive pill in it to stop SPIKING.. without it in you will find that it will boost spike till cut in some heavy footed moments
yea im sure thats how mine is also, have my racepro tap 2 put back in so 10-12psi again, think i need a shorter pipe tho for controller, allgood, lets try get this BF boostn
hey guys im selling my car and gona try get a rs legacy but it is hard not working at the mo to get one.
im not giving up i want to upgrade to sumthing better
