hey guys well i put my pod filter on today and it seems much better at idle and turbo is spoilling up at about 3500rpm to 4000rpm
  • Replies 56
thats good, pod will make spool alot louder but thats about it, make some induction pipes going 2 it, im full boost near 4000revs also on a vf8 but have afew mods
thats a bit high revs - u using a tap?
na took tap off,2nd gear, thats when it pulls hard, if i just boost from 1st its mint, want 12psi again :D just gota do rear axle
I'll check my TD05 when it hits full boost in 2nd then.
Normally you would check in 3rd or 4th to load the engine up more.
change your spark plugs! :-\
i had the same problem in my last subi
was old plugs, it would start to foul just before i hit boost, but would run fine when not boosting and wasn't very responsive
i changed the plugs to iridium plugs and i was boosting normally again :)
p.s; it this doesnt fix it then change your coils back to factory legacy rs ones.
dunno the deal bout sti ones but it wont make a difference in your case
