Just seen someone selling a 2007 Legacy GT Spec B 6 Speed Swap so Axles, Driveshafts, Subframes, Diffs the lot. Now what I want to know is am I correct in saying that this drivetrain is the same as the WRX STI of that year and if so would this be an easy swap into an 01 WRX?
It won't be an easy swap to anything else.
Everything is slightly different to a comparable year sti.
An 01 will need a speed signal from the trans which later ones take from the ABS system instead so you need to install the sensor for that also.
Those rear axles are weird ones with r180 size on the inside and r160 on the outside
  • Similar Content
