Sign in to follow this
BMCracer
Steering wheel buttons can't go through station presets?
On my car the up and down buttons ( under the volume buttons ) on the steering wheel scan the band. Is there a way to change that so instead of scanning, it would change to the next preset station? Seems kind of pointless having steering wheel controls to keep your hands on the wheel, but they don't do the most common operations. My stereo is the same as below
s-l1600 (2).jpg (243.72 KiB) Viewed 168 times
2007 NZ new 3.0 Spec B 5EAT wagon in Brilliant Silver 39D
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By Hinkie
      Hi Subagurus
      Inspired by Super Guitar Guy  and Super Stereo Installer I thought I'd share some information in appreciation of the super time and work these guys and everyone else generously shares here, thank you.
      I've decided to do the double DIN and install one of the new Kenwood DNX9180DABS HU with Navi and add the dashcam. Currently collecting my bits, plans, work in progress. I figure if I can get all that kit running my Outback will be more capable than a new one, (no dashcam!) and a hell of a lot cheaper! Plan is to use the existing amp. I think they feed 80W (RMS?) per channel but that's not confirmed. Still knowing how they perform I am happy enough with the McIntosh amp and speakers.
      In the mean time I wanted to swap the Japanese banded PF-4062l head unit with an (ex NZ GT Legacy) PF-2551l for the standard NZ bands.  Thought must be too easy!
      Wrong!
      Swapping the units, which have the same plugs (not necessarily the same wires though!) proved to make both the McIntosh display and the upper Nav screen (Still in Japanese) just flash and will not work....  Quickly turn off....
      After much thought and studying most of the Internet and with a little help from Jeremy I figured that the 4062 will have, being a later unit, a lot of stuff that integrates with the Jap Nav gear, and that it all connects through the 20 pin J800 socket that has a heap of wires that I've not traced, but they connect to the Bus, what ever smarts are therein, no doubt the intermediate SWC smarts (not found how Subaru interface the control with the HU, but probably academic) and the Nav and who knows what else. The more common Subaru 20 pin plug J901 just has the power lights and antenna amp power - all essential to run the Head Unit.
      So....Legacy PF-2551l will run fine in a JDM Outback as an interim radio for me. Woot. (without steering wheel controls connected) when one simply does not plug in the back J800 plug - for anyone wanting to try that. Will keep me going for now.
      For the planned Double Din install I've bought a "junk" PF-4062l from Croooober for its sockets, especially the 20pin DIN wired female socket. My original thought was to use all the sockets as that would smooth the interconnection, now that expectation I've now pretty much shown to probably be wrong so arguably it was an expensive 20pin DIN, but then seems they're not otherwise available at any price.... Part of the cost! For anyone wanting to also do this conversion I figure a junked EF-1208l amp could also be used as a 20pin DIN socket part source for the HU end to run to the Mac amp being used in the car. That would have been cheaper for me, but committed now. There's currently a cheap one going to the first taker....
      I bought some RCA leads which I'll splice into the newly imported DIN plug lead at HU end which I figure will be robust enough. Also will need to feed the amp on (I assume) with the +12V "Power on" to turn the amp on. Plan to find the Original Subaru GPS existing device and swap it with the new Kenwood one. Seems no point installing the digital antenna on the windscreen as I think (open to correction) there is no digital audio around to connect to in New Zealand, especially the Wellington region. Yet to resolve issues anticipated. The McIntosh kitted 'rus feature 4 speakers in each front door. The Kenwood has some rel sophisticated frequency smarts for feeding different speakers different frequencies, particularly to protect tweeters. But they don't go so far as 4 different speakers per front channel with intermediate single feeding amp channels(!). I don't know but expect there is a crossover network in each front door (anyone know?) which'll do the frequency distribution just fine. So that leaves me with the expected question of what cut off frequency to feed the sub woofer, and whether I trim any base of the four door channels. It might all just work without fiddling with any EQ. Not yet figured out what to do with the Nav unit, expect the Backing CAM works and is appreciated, all be it at a liney resolution. Be nice to have a 720p front and rear cameras with the front one thru a replacement 720p screen mounted between the vents, and the higher defn rear cam thru the Kenwood. Not figured that bit out. Comments welcomed.
    • By Jccmuir
      Howdy folks, i need to repaint the whole piece of trim on the rear hatch of '08 gtb facelift. The piece that houses the reverse and fog lights, badge etc but cannot figure out what im missing, have the interior of the hatch off and found the obvious two 10mm nuts to remove but otherwise i see nothing. Any help would be greatly appreciated!
    • By morry10nz
      Car - 2006 Subaru Legacy 3.0R-B WAGON with McIntosh factory 12 speaker system.
      So I have the standard issue that the factory McIntosh sub has split (I got it repaired at Axent Audio in Auckland but within a few weeks it had split in another place) so I am keen to replace it.
      I have fitted a blue-tooth kit to the factory McIntosh head unit as I quite like the factory set up, and basically couldn't justify the massive effort and price in changing out the head unit with it being interconnected with the dual zone climate a/c unit.
      I have found a replacement Sub which is a KENWOOD EXCELON KFC-XW800F SHALLOW-MOUNT 8″ 4-OHM SUBWOOFER from Driving Sound on Dominion Road - kenwood-excelon-kfc-xw800f-shallow-mount-8-4-ohm-subwoofer. The McIntosh is 4 ohm and so is the Kenwood unit I have found.
      I like my music but wouldn't say I particularly crank it all that much, thus I am not keen to go and "start again" with the whole system in order to get some that is next level.
      I want to know if the Kenwood unit will work as a straight replacement and will work with the factory amp (under passenger seat) as I have read some forums which make me think it won't, but the people at Driving Sound seem to think it will.
      The next issue is fitting it into the back right corner of my wagon, as although the unit isn't any deeper it is slightly wider overall (behind the front of the sub) so the bracket space needs to be increased. I could pay another $200 bucks and get  box for it but then I loose some boot space the factory look which is quite important to me.
      As I am new to Auckland, I wondered if there is an automotive fabricator/chippie or someone else handy who I should/could get to do it. I just need some assistance in carving out some more space in that back right corner and creating a slot for the new sub. I am happy to pay the money to get it done properly as opposed to stuffing it up myself! A quick Google landed me on "Stu's Trim and Sound in Manukau. I am sure they could do it easily enough - any other suggestions or comments on the above in terms of things I have overlooked?!
      cheers. Mark
