Hey guys
I haven't been driving my car much, maybe only once a week lately. I've been super busy with work and other things and totally forgot to check my fluids like I usually do every week or 2.
I took the car for a big drive, 2 hours the other night. I had not had the car out for a good spirited drive in a while so I was doing pulls and that. I was hearing this sloshing/water sound and had no idea what it was.
I checked my fluids this morning and realized my coolant was quite low! It was below the 2nd line by about 1 inch. I still had coolant in there but it was below the line.
I never had my temperature gauge go up or coolant light come on but I am a bit concerned at the damage I could have done during that time.
Is it likely to have caused damage or because I still had some coolant and I have not driven much I might be ok?
Same answer as usual, you've killed it, replace engine immediately.
Do you understand the function of the coolant bottle?
How much coolant is in your radiator?
A much much better question if you're genuinely down on coolant would be "where is my coolant going" since it's a (relatively) closed system and losses even over several years should amount to very very little.
