Hi all,
My reversing camera has fallen/been ripped off.  It was small, cubical and mounted to the left of the number plate lights to an approx 3cm square hole.    It appears to have been wired with a small black cable with very thin white and red wires surrounded by fine wire shielding. Probably 6V.   There are various reasonably priced reversing cameras on Trade Me but they come with their own phono plug/co-ax style cable as well as 12V power/earth leads, and I'd rather solder/connect at the rear door and not have to run cable through the car and take the screen out to connect up.
Can anyone recommend a camera and help/point me to fitting/wiring instructions?
Many thanks
Bill
Do you know if it was an OEM one or aftermarket? Assuming the car is an '06 Outback I'm guessing aftermarket. As a guess, the red wire will be +12V, white will be the video signal, and the shield will be the ground if there's no other conductors. I would be really surprised if it was not 12V, unless there's a module somewhere that's stepping the power down. Usually they're 12V and just take a tap off the reverse lights.
    574.7k
