Hey team,
havent had much luck with the google-ing but just wondering if anyone knows the clearance underneath an a gc8 STI bucket seat (the red and black ones if it matters?). Looking at an underseat sub for my bc5 (which has the gc8 seats) and its looking pretty tight (maybe a touch over 60mm) but wondering if anyone knows or has had similar experiences running an underseat sub.
Cheers!
Can’t answer that but what’s your cars under carpet sound deadening like?
Some models have thicker foam or felt that you can trim out to gain 1-3cm clearance  Thickness depends on model trim Eg higher spec models can be thicker legacy maybe thicker than Impreza. And newer car have more thickness or density.
its an RA haha so next to no sound deadening at all. . . but yeah valid point, i'll have to remove the floor mat too to get a bit of extra clearance as well. Will probably just have to dummy something up and see how it physically clears the space
Carpet places can make mats.
They can just do the outer loop stitching on any carpet. You could get an old matching mat and cut it to shape then have them do the outer trim.  That way you get a tiny mat for the foot area.
