**Sparkplug cross threded in cyilnder**
subaru-mania
went to pull the spark plug out of the Xt and noticed the sparkplug was on alot more of an angle than the other 3 plugs. So i pulled it out to take a look and the thread in the cylinder is pretty Fu*ked and it wont go back in. I think it could need a re tap.. how do u go about re tapping a new thread without all the metal flake going into the cylinder?
Since when were spark plug threads in the rocker covers?
Youre in the brown stuff i think mate. If the thread is totally rooted i cant think of any way to fix it other than take the head off and do it properly....at which point it would be easier to slam a new head on there
You can get a sparkplug thread re-tapping kit from powerbuilt i.e.from Repco.
There's possibly a method for doing it while the head is still in place but you'd want to be really really really sure that you've gotten all the swarf out of the cylinder.
I would have guessed something like do the re-tapping with that cylinder at TDC. Then once finished either blow it out with compressed air or suck it out with some sort of small hose over the end of a vacuum cleaner hose. Then wind it down to BDC and reapeat to hopefully remove all that is left afterwards. Gonna be a right pain in the ass to make sure its all clear though.
Its on a ea82t so the hole is on the head I was thinking cranking the motor over by hand untill i see the piston covering the hole then re tap and the shaving will fall onto top of piston then suck it up off the piston with a vacuum cleaner or air compressor? do u think this would work?
 subaru-mania said:
or just leave it untill i do the head gasket at some point as i wont be driving it for a couple more months.
If you're pulling heads off in the near future you've got your answer. Going to be a million times better and safer to do with the heads off the block.
 Koom']
wouldn't be a good look if i started it up with metal flakes in the bore :D
 subaru-mania']
Might make pretty sparks out the exhaust as the filings make there way out though :D
 Koom']
haha yea it would look cool at nite :D
yup been here not so long ago with the rx
is it the front one on the passenger side below the alternator
here is how u do it in situ .....
remove every thing above it to give u good access...
I used a Helicoil spark plug kit (Name brand i think better)
retap hole using the helicoil stepped tap making sure it square, I coat the tap in grease so most of the swarf sticks to it (damn i should not give all my tricks away)
Insert the helicoil and break of the wee tag using a long nose pliers(and hopefully it dont fall in cylinder) if it does I use a wee magnet pick up :)
Blow the cylinder out with a blast of air to get any left over swarf out
crank the car over with no plug in ( also disconnect other plugs as they do run on 3 actually will run on 2)
install everything
and done
I have spare heads here if needed
also a EA82 Carby head is different to a EA82 EFI head(including turbo)
install everything
and done
Spot on DRFVDR it sure is the plug were alternator is ur way sounds logical ill give it a shot
I use helicoils alot at work for various things, including munted spark plug holes.
Only other bit of advice i can offer is to use plenty of loctite when putting the helicoil in.
 subaru-mania said:
do they hold the spark plug in tight? also why not just re-tap if its not to munted if u could clean it up with a tap the same mm as a sparkplug
you could try clean it up with a tap it may work but it'll never be as good, a properly fitted helicoil should be stronger than the factory thread.
i use them at work sometimes of we get a really bad sump plug thread, especially with alloy sumps.
