Upgrading from TD05..?
Ryan
 Ichi Ban said:
Just saying that yellows are ok up to this mark, Wouldn't go past this point!
So many people replace injectors and they are nowhere near 218Kw
Remember some dynos are harder than others ;)
I agree re, different dyno's
And it really up to the tuner/engine builder and owner to discuss power output and fuel requirements
Lets face it, when most people buy a bigger turbo etc, they do not do the calculations to work out airflow and the fuel required
Hence many end up with atleast two trips to the dyno (after finding their fuel system is maxed out to soon)
TD05-18g, yellow 440cc, walbro fuel pump and link G4 will see you right. If you are shooting for anything much over 200kw atw id recommend you go aftermarket injectors.
Depending on condition you might want to get a rebuild to standard spec/freshen up or upgrade to forgies etc.
You gearbox/clutch might not stand up to much abuse with this level of power.
Cheap, reliable, good power-PICK TWO!
how much power do you think i'd be putting out at the wheels (rear wheels only ;D)- standard internals 1992 rs engine with 118km, TD05 with 18g wheel, siamese downpipe into 2 1/2 exhaust, split fuel rail running yellows, 16psi on chipped ecu, fat tank intake, all new iridium plugs right round etc?
just want a rough idea of what to expect on chch clubsub dyno day next month....
i just got some gtb yellows from bits for isuzu and subaru today. they were 360 retail and got them for 100 plus gst and can get another set in rails for 160 plus from another car breaker if anyone wants them... 3 month warranty etc.... pm me for order
150kw is my guess. What do i win for getting closest?
I scored 130kw on a TD05 at 12psi with no other mods and a stock computer...maybe my original guesstimate was a little low
