Removing steering wheel?
Ryan
How do you remove the steering wheel in a version 2 WRX STi? I've undone the big main centre bolt, what else is there? Got the standard Nardi wheel on it at the mo, I've got a 2002 .WRX Momo wheel to put on (hopefully it fits?!),
 subieboy']
[quote name='Ryan said:
Ahh cheers, I did try pulling but obviously not hard enough! /quote]
Or even easier
Get yourself a gear puller (useful for other stuff as well), and a couple of turns of a spanner all done...
Best $20 you will ever spend
As long as u dont damaged the thread! ;)
 ReubenH']
[quote name='DPI said:
Don't 2002 wheels have Airbags?
Cover up the SRS airbag logo, and remove the detonator, good as gold (if the wheel physically fits)
You will need the entire steering column, as they use a different clockwheel, otherwise you're going to be hornless, and therefore WOFless
you do realise that the static electricity in your body can be enough to set it off right? and dont joke about it man, it will take your head off
we have set large curtain ones off at work and there pretty unspectacular, if theres no wires into the plug then u cant set it off, i can check the virm tomorrow but im unsure if theres even mention of having a bag in non srs cars. still this could cause problems at wof time with the inspector seeing a bag and no light
