Hello,
well i was reading the Revspeed Japanese performance magazine lastnight. And it seems to be popular to bore out the Legacy throttle body entry or buy one that is larger. Has any one attempted this, and did it yeild significant results?
Will
Not really. Many set-ups push enough CFM through the OE throttle body and make sufficent power.
There are gains to be had no doubt but they are small.
I remember a large discussion about this on the old forums.
What i took away from it was that there's not enough gain to make it worth it. But there was argument about that.
Personally, I think it's one to do when you're trying to brake the 300KW mark. ;)
interestingly i have found that the GT throttlebody is small compared to the GTB 206kw one, which uses the same unit found on sti wrx's
basically legacy with yellow injectors has the sti larger diameter throttlebody, so i've found at the wreckers anyway
    574.6k
