Best head to put on CD block?
Ryan
 JoKer']
TT/V3 heads? Guessing totally BUT how abut all CD questions in one thread? :D
Haha yeah I'll limit myself to 2 heads soz ;)
[quote name='SPANKU said:
best heads for phase one motors are ver 3 and 4 size=4]STI [/size]heads
the ver4 Heads are more aggressive apparently
Yeah I thought it may have been V3 from memory, can anyone else confirm this?
do a searh this was a big topic not long ago. there is little different between the 3s and the 4s but it looks the same
there is a set on trademe that im selling at the moment for $450.00 its boxed and ready to go
 Ryan']
No need to confirm he' s correct, they aren't the best heads but the best to use the phase 1 manifold.
Better heads would be V5/V6 heads but would require the matched Intake manifold.
think with the STI cams you can rev up to 8250-9000rpm redling as the lifters are more soldid and shims underbuckets. remember seeing GTB 7000 rpm?. depending if you want to just get your car going or you want something serious with your motor?
Ryan, that blown EJ20R of yours is perfectly good for a build with a CD block. That's basically what i did with mine, been running sweet for 25,000K's now with V3 STi stuff strapped on, such as manifolds and ECU and such, with VF39.
And San, auto GT's are 7000, cause they have the EJ20H. Manuals with the EJ20R are 7500, and mine's shown no issue with the STi's redline. Part numbers on the cams for 20R's and STi 20K's are the same, but that's a discussion had before. Also, apparently V3 is shim over. V4 is the shim under engine. ( <-- woops, not so) I can't recall if my GTB (BG5C, so same gen as V4) was shim under or over... i have pics though.
pic 1 and pic 2
Can anyone tell if that's shim over bucket or shim under? I'm still learning.
I'm still trying to figure out exactly what is the same between proper GTB, and STi, and what is different. I was once told they were the same, and shown proof by someone who knows a feck load more than i. But lately i've been finding out some tid bits that confirm, and bits disprove that claim.
