fuel rails my first mod
95guy
Hi clubbers.
Just wondering if I have fuel rails on my car as I know nothing about subis, but am very keen to learn.
I was told if you don't have em you can get wear on one of the pistons?
dunno
any help will be rad
Thanks guys
They all have fuel rails. If they don't have split rails then the last cylinder can get a fuel shortage under high loads. Basically in stock form think of it as one big loop going to the cylinders one after the other so if the fuel pressure isn't keeping up then the last one in the line will get low. The split rail mod splits the flow into two paths left and right heads each get a dedicated line. And in general keeps things more even between each cylinder.
Haven't done it myself so my knowledge is purely from reading others experiences so someone who has physically done it themselves will probably do a better job explaining it.
Beat me to it adikt.
Also if car is stock, as you say its the first mod you're thinking about, i wouldn't really say its needed. People only seem to do it on medium to large power builds
Edited by Andy_Mac
I don't know about that "4th piston often has problems" bit - I think it might be somewhat hearsay.
Put it this way - flat out, 1 of my injectors can dump approximately the same amount of fuel as all 4 on a WRX. And I don't have fuelling issues, with non-split factory rails. If you think about how the fuel pressure setup works (FPR at the end of the rails) you should always have fuel pressure at the injector, unless your pump can't keep up with the flow + pressure demand.
I really don't know the history of this car but its not stolen lol
its non sti done mega ks, has a leaking rocket cover. been lowered blow off poddie.and still goes hard, doesn't move my face like Arnold wisemans RS kickn tho !
Thanks to everyone that made a comment.
much love!!!
Edited by 95guy
I read into it a long time ago and there was a different science to it. Fecked if i can remember where or why.
Factory airbox draws in cold air, more of it and less restrictive. Also prevents you killing the maf from vibration. Bov can give weird stumbling idle issues too.
Advantage of fresh oil, filters and an ecu reset is so the ecu is starting fresh, instead of having to totally relearn driving patterns.
Also, you'll quickly find whos advice to take with a pinch of salt. Some people can be a um... a touch blunt about things, but their motivations are in the right place ;-)
Welcome along, hope to see yah at an event or 2 in the near future :-)
