HannesNel
Headlight clearing
7 posts in this topic
HI Guys
So I was planning to go the wetsand route (600,800,2000) then clearcoat it and wax it.
Now i saw this video :
Did anyone try it? comments? what would last longer and be better for the headlights?
Share this post
Link to post
I used the Mothers NuLens stuff. Did a great job.
Comes with 800, 1200 and 3000 sanding pads, PowerBall and NuLens clear plastic polish.
Have a nosey in my Garage thread (in my forum signature) if you're curious.
I know guys here have done the multiple grit wet sanding, Clear, then wax.
Probably the only thing I can think of is to use an Enamel Clear (someone correct me if you should use Lacquer).
Share this post
Link to post
I just used the CRC headlight doctor product on my Nissan Fuga and was really impressed with the result. Took a bit of elbow grease but the missus helped out xD
Can get it from like repco on sale for like $13
Share this post
Link to post
I've used the RainX kit which sounds similar to the kit above, and its great, but the tiny sanding pads clog so quickly it becomes kinda hard to use.
I'd consider purchasing 3 big sheets of sandpaper for about $1 each and some headlight sealer. Probably similar price all up but it will last you longer.
Share this post
Link to post
Exactly. Wet sand paper too. That way the paper doesn't clog up as fast. The 3000 grit pad in the NuLens kit is basically like a fine scotch brite pad.
Share this post
Link to post
 Yup, nice - much better way to go about it now that I've purchased the entire kit.
Share this post
Link to post
