How to put a v8 scoop on 92 wrx?
all depends on the scoop you get....if its a str8 bolt on you can do it and just need to paint it....if its not a direct bolt on you prob looking at a couple hundy to paint'n'fit + the cost of scoop...direct bolt on ones are easier and cheapa
mines fiberglass i got it ages ago for $250 all up was stocked.
i'm thinking about going alloy now only cause i have a crack thats starting to look worse, well i notice it :-\ just have to get it painted after but while i'm at it might as well touch up the front bumper again and get a lip lol where does it stop.
  • 3 weeks later...
im pretty sure Nick aka WRXERs scoop came off when he came down the straight at ruapuna too.
They seem to need to be bolted AND glued on if you want to hit high speeds ie track speeds.
iv got a v4 wrx scoop on my 91 rs legacy, all i did was screw it on then fibreglass around it to make it look as 1 piece. at the moment im fitting a v4 wrx front bumper to the rs, had to do alot of cutting to the bumper to fit over front mount etc, but once finished, it will be seamless to the front gaurds (im trying to keep body as smooth as possible)
