How do you get rid of the alarm that goes off with door open!
Nic
  • 3 months later...
I opened up the box in my V7 (I believe it's the BCM?) and de-soldered the little speaker that does the various chimes. So no more ding ding if I have the door open or when I'm in reverse.
I HATE little beeping sounds. My family's old Corona used to go DING DING DING at over 104kmh, hammer quickly fixed that.
 Drunkenmonkey']
[quote name='Scoobydoo said:
The beeping? There's a box with a plug in under the dash. It un plugs and gets rid of the beep.
that also gets rid of the ring light, under the ddash with the loom for the ign there is a 2 pin plug undo that and it keeps the ring light
Ring light, around the ignition?
So to get the beeper to shut up and keep the ignition ring light working - instead of unplugging or (as I would prefer) removing then smashing to peices with a hammer, look for the 2-pin loom under the dash and remove that?
 JoKer']
Is there a way to destory the charm, whilst preserving the ignition ring? Apart from taking it apart and disconnecting the speaker itself..
no
YES
  • 11 months later...
Necro'ing:
Hold the door button on the side.
Or solder the wires together to keep constant circuitry that are in the doot button.(I haven't opened it before, so not sure whether the door buttion's a circuit breaker or completer) I'd assume completer, so solder, if it's a breaker,well justcut the wires and tape them up.
When CS Dad was doing a wiring install for some gauges we had a play with what wires did what while trying to find a switched power feed, and in a loom, we found what we believed to be the wire controlling the ding. I told him to note down what colour it was. Did he? No. So that knowledge is lost to the ether haha
CS Dad gets pensieve from cupboard, extracts relevant memory from mind, wait !! there is Scoobydoo in the passenger seat playing with his high tech HTC while others are working, the fog clears further and there are seen some connectors around the steering column, it is the black one with one wire in it that is unplugged, the door alarm is suddenly silent. Pensieve goes back into the cupboard. ;)
 94 Leone said:
Necro'ing:
And then when someone breaks into your drivers door the alarm doesn't go off.
