Big End
petrolheadjman
Ok i have used search but didn't find quite what i was looking for.
I am a bit of a noob on this so please go easy haha
Anyways i think my big end is going (nugga nugga) and wonering what my options are with getting it sorted? ie can i replace the short block? or find a whole new engine
I have a non turbo TS-R bh5 legacy btw and for now want to keep it non turbo as i don't have a huge budget
thanks for any help
From what I've heard a big end failure should be pretty obvious. What are the symptoms and sounds that it's making?
Does the noise go away when the engine is warmed up? If so it could just be piston slap which is pretty common with higher mileage Subaru's
 WRXONP said:
nah thats deffo not a big end man...a big end sounds like a repo man knocking on your front door LOL LOL...and he knocks fast and hard LOL
sounds like lifters to me...whens the last time u changed the oil?
Around 5k km ago iirc. I will be doing an oil change shortly, going to order some MBL8 to put through it
 DRFVDR said:
A good flush is to run a 50 50 mix of ATF and engine oil
And just do this before an oil change?
I was reading up though, and somewhere it said that this can be dangerous if you have a car with high k's (as i do) because large clumps of shit can dislodge and clog up your fuel system. How true is this?
fuel system in the oil lol??
nah man STP engine flush (in a red bottle) works really well have used it in alot of cars ive owned..cleanes the inside up like brand new plus it keeps your new oil gold for aaages...if it is your lifters making noise the engine flush will normally unblock the ports on the hydraulic lifters and get all the gunk out...if your engine has lifters that is ???
could be cambelt bearings ?
use a screw driver (a pretty long one) and stick it on the actual cylinder head it self and tell us if u can hear the exact noise through the screw driver... also place the screw driver in different spots ie alternator,cambelt cover in various places etc etc...screw driver works like a stethoscope :)
any sort of a flush can dislodge crap :)
wont effect fuel system as it is oil in the crankcase :) not fuel in the fuel tank :)
run i for a few K's then change to regular oil...
I run diesel oil in my cars as a/ I get it for free :) and b/ it runs more detergents so helps to keep the engine clean :)
Lol sorry i'm just learning :P
Ok will give that a shot tonight :) thanks for all the advice btw guys, just really sucks hearing my engine sounding like this
