help please im out of ideas :(
toad
  • Replies 78
came home at lunch from polytek and looked on the leads to find numbers and couldnt find any and removed injectors and the o rings were fine that i could tell. ive convinced a mechanic from work to come round for a box of alc to have a look and see what he can do 2moro so fingers crossed.
hope you de primed the fuel rails before pulling injectors
This can cause a cylinder to flood and then it hydraulics when you go to start and 9/10 times will bend a rod
new sparks plugs went well as other iridium ones where fouled up, leaking fuel from one of the injectors so replacing all o rings on injectors, split rail and breather tank goin in it while im there.
yea dude u were right thanks heaps! 1 other question. there is a pcv valve (think that what its called) on the underside of the intake manifold at the back. where do i connect that when i put in a catch can as at the moment it connects to the crankcase breather.
blank the pcv at the manifold (ie remove it and plug the manifold) run the crank breather hose to the catch can
also need to consider the two rocker cover breathers and feed them into a catch can too
Have seen many issues with catch cans
try and run the lh breather to a catch can on the rh side and vise versa (means running two cans but will dramatically reduce the amount of oil in the cans)
Catch can? Why bother? my breathers go to the exhaust, Saves draining the can and no fumes under your bonnet.
Back pressure from exhaust prevented by using the PCV fitted to the lower bend on the down pipe. No smoke from behind unless sump gets over filled by even a fraction.
Works well.
Works well.
so under full throttle there will be pressure in the exhaust, which will close the pcv - correct?
But this is when the engine crankcase NEEDS to breathe MOST
 Ichi Ban']
Works well.
Having a 65mm exhaust from the bend on the front down pipe with a venturi pipe fitted at this point there is no pressure. infact there is a partial vacuum at full power of minus -4 millibar at this point. Crankcase pressure at this same power with system connected was / is plus +3 millibar. Did some careful research and tests.
As for exhaust fire?? no risk or problems there. Just a huge smoke cloud like the turbo has crapped out IF i have over filled the sump even slightly and corner real hard. Works well......Pcv sounds like a ticking tappet at idle LOL!
 Ichi Ban said:
might be ok for street car, but NO good for track work
Subaru Ej engine will surge oil up breathers under hard cornering (esp Manfeild)
Did puke yesterday, No issues.(soopercooler tests) The rocker cover breathers have been led back to a cross piece above the crank case breather so i reckon most of the blown oil actually returns to the sump at this point, I have had an occasional comment on wisps of blue smoke at bent sprints and hill climbs from concerned spectators but is of no concern as i know what the cause is.
Fully baffled race sump will probably sort it out completely, but like you say, it's a street car so all good.
Thats how the V8 boys boys do it on a super charged set up, But they have no PCV at all, each head breather goes stright to a venturi in each header, most v8 parts places even sell a kit to do it. I've read creating a vacuum in the crank case is ment to be good for extra power, I believe some people even attach a vacuum pump to the crank case.
Indeed crankcase vacuum does increase power output
We run an extra stage on the dry sump on the super saloon just for this reason, and you can run lighter oil control ring pressure too
NOTE MAX 10"Hg, any more than this causes gudgeon pin seizures from lack of oiling
