Final gear ration on JDM GT 5EAT?
webup
Duno how to tell without it, someone might have an idea...
If not find Gearbox number and go to this link...
http://spda-online.ca/modules/tinycontent/rewrite/tc_28.html
Use search function on the page. Gearbox number is on the top of bell housing from memory,I know in my WRX we found it from the top while the box was in place after some buggering around with a good torch.
Whoops didnt even click you were looking for an Auto.
BP is later model isnt it? so odds are its original box? Might be worth taking a punt on asking a Subaru dealer to check model number or Chasis code for what sort of box it came from?
Lots of assumptions there...
 newsuba said:
From the 2003 NZ Legacy brochure...
2.0 GT 5AT gear ratios.
1. 3.540
2. 2.264
3. 1.471
4. 1.000
5. 0.834
Final drive 3.583
You the man!!!
Thanks all for your input!
Yes original box...now i just need to find a Valvebody from a wrecker.
 webup']
[quote name='webup said:
anyone know the ratio please?
depends on your spec
the JDM BP/BL legacy with the EJ20X engine had either a 3.272 or 3.583 rear diff ratio
So they came with either? do you happen to know what criteria changed which option went into what model?
no i dont
for some reason it depends on the model only
GT, GTB, and all the other GT models (there are quite a few in japan)
 webup']
1. 3.540
2. 2.264
3. 1.471
4. 1.000
5. 0.834
Final drive 3.583
You the man!!!
Whats wrong with your valve body? I have the relearn process to set up the solenoids vs the clutch packs
If you need a solenoid thenI can prob help you out
