Question on turbo conversion....
petrolheadjman
I have a 1998 legacy TS-R and Yes I do realise It will be easier to sell up, buy gtb and make single but I want to do this for the experience too.
Regarding wiring, will it be possible to get someone to mate my loom to say a version 3 wrx loom? Or is this in the too hard basket and is there a version that is more suited to mating with a BH legacy.
I realise completely re-looming the car will be required but that’s fine
I don’t need AC but keeping the heater controls will be nice
It is possible to mate looms together but its not worth it. I'm saying that as I'm sitting here amongst an ECU <-> Engine loom that I'm making from scratch.
You especially don't want to be pulling the loom out of your car as there is no "engine" loom separate from the entire body loom. Its just one big mass of wires and the plugs for everything else in the car don't often match up between models?
If the plugs on the ECU are the same (up to the phase II change i.e. before and including V4 STI and BG5b) then you can swap the pins around in the back of the plugs to get them to the correct spot but I'd guess the N/A models are missing a bunch of wires from the ECU to the Engine.
Just buy a GTB. They're cheap. Buy one with a dead motor and drop an engine in it and they're even cheaper. A good condition TS-R is prob worth more than an average GTB anyway.
 petrolheadjman said:
damn. probably not. mmmmmm
and my TS-R isn't worth anything, its in pretty mint nick just done 240xxx k's so no one will touch with barge pole
240,000k's - it's just been run-in
My wagon has clicked over 316,050k's on the near stock drivetrain
 dacerx said:
Why supercharge at all? We aren't running holdens here
lol, consider yourself trolled ;p
and ummmm its a fairly unusual mod, do some research, find out exactly how the looms differ and work out the best plan
for example, i intended to mod my impreza 1.6 loom -> ver3 but found sorting the engine side would be a total waste of time. as Koom said, find out how similar the TS-R ecu plugs are first and go from there.
i suggest a sunny afternoon at the wreckers if they let you wander around :)
nah DVKE ( 40~ mins more north)
but I chucked a turbo on my 250T and it seemed reasonably happy with it.... worked for a few months and dint break anything, excess oil leeks saw stop to that : no one has said it was a bad idea yet! (fully was not legal in any way at the time other than the car had a WOF that was current when I bought it.....
