that is alot of power!
me and jamie done a few already.
my first one was off my ver5 ra.
  • Replies 94
Just a couple questions, I have heard of the "phenolic gasket" trick to get the idle control to clear the power steering fluid reservoir....
But I also hear that people have issues with bonnet clearance with the flipped manifold mod as well? (mainly legacies?)
I have a v4 sti, if I flip the manifold (by turning 180) and put 2 sets of phenolic gaskets on, will I have any clearance issues?
Also, are there going to be any issues with throttle linkage clearance with the alternator bracket? I have the alloy bracket and it looks from my eye-ball-ometer that it might foul a bit.
You can get gaskets that are around 5mm thick or bigger so that should sort the power steering issue
Bonnet clearance shouldn't be an issue on V4 if you get the angle right with the silicone joiner and IC pipe
Yea the throttle linkage does hit the alternator (sp) bracket, grinder fixes this up ;) you gota cut it up for the flipped alternator (sp) anyways
Then you got to re-plumb everything, which id say would be a right cun t if you were running a stock intake and turbo placement, was still a bit of work with a custom intake, I probably wouldn't do this mod unless you relocate the turbo and obliviously custom intake, then the header tank will be in the way... so thats got to be relocated. And then there will still be wee bits and pieces that will need sorting, all in all its quite a bit of work involved but if ya can do it ya self and make a good job of it pays off! and its a hell of a lota fun doing it ;D
  • 2 months later...
you can avoid the powersteering issue by simply using the remote resourvior tht sum models have factory. wil give heapz of clearance. or gt a link ecu then you dnt need the idle control valve.
or use a Nissan one with bit of home made flange for the win :P
  • 2 months later...
just bought one of these so hopefully it gets me around the issue of moving the alternator, 'aparently' it wont hit my bonnet....fingers crossed.
Guest SPANKU
heres my old car done this about 4 years ago
the new one: with top feed 800cc injectors
but im going to be ussing a EJ25 manifold, its flatter and dont point up. if u ever seen Tony's STI hes ussing the same one. the thing is you got to get a ver5 injectors
Guest vf20/21bg5
my alteration for a flipped manifold cost me just $90 for the chrome bracket($70 if not chromed.....043.jpg?t=1280145186DARRYNS044.jpg?t=1280145270
True? The runners look like V5 but the centre chamber looks nothing like. Was thinking it might of had the centre off one of the early IM's chopped and spliced.
looks more v3-4ish but yea its been modded, bit like mine.
haha lou. thats the brake booster one way valve.
it looks like a standard manifold, just with the centre cut out and fliped over like a forwards roll.
 wrx_lou said:
Do the 3/4s not have ICV?
you could be right v5/6 is the only one that dont. i could tell if it was a front on pic, but yea either way its had a bit of work done.
lol, I dunno what it does, but isnt it usualy on that side? Fuck its been that long since I've seen a full assemble EJ I can't even picture it.
 wrx_lou said:
lol, I dunno what it does, but isnt it usualy on that side? f*** its been that long since I've seen a full assemble EJ I can't even picture it.
yea v1-4 is on the passenger side. i have seen this car but it was a long time ago.
but yea from that front on pic you are right, its a modded v5-6 mani.
    574.6k
