Boost gauge issue
_reido_
Hi guys, hopefully someone can help me
I noticed today that my boost gauge is only working on the vacuum side of the gauge, when I accelerate the boost gauge will go no higher than zero. Is my gauge stuffed or is there something else I should be looking at?
Thanks
Andrew
Which line did you tap to put the gauge in? If you tapped the brake booster one off the manifold it has a 1-way valve in it so you can't fill your brake booster, with, err, boost :P
There may be a couple of others with 1-way valves but that's the only one I know of.
 WRXONP']
[quote name='Timmah said:
My boost gauge stopped working today, was only reading zero. size=3]Popped the boot[/size], found the the hose had fallen off. Perhaps you should check for that or a small leak somewhere
you trade upto a porsche turbo now bro :P
Just some loooong as vac lines ;)
